anthonycwmak
Feb 14, 2024Follower
Orbi with Superloop?
Is it possible to use Netgear Orbi with Superloop's NBN? >>If so, is there any special setup that is required? << (I have an Orbi Mesh WiFi 6 System - AX5400. And currently I have a modem from...
- Oct 04, 2024
This is from iiNet, and I haven’t used it. But seems pretty good step by step instructions
https://help.iinet.net.au/how-set-netgear-orbi-rbk50-nbn-fttp
Feb 14, 2024Guru - Experienced User
Something to discuss with the ISP.
Orbi works with most ISP equipment with a ethernet connection to the Orbi router.
Good Luck.
