anthonycwmak
Feb 14, 2024Follower
Orbi with Superloop?
Is it possible to use Netgear Orbi with Superloop's NBN? >>If so, is there any special setup that is required? << (I have an Orbi Mesh WiFi 6 System - AX5400. And currently I have a modem from...
- Oct 04, 2024
This is from iiNet, and I haven’t used it. But seems pretty good step by step instructions
https://help.iinet.net.au/how-set-netgear-orbi-rbk50-nbn-fttp
Feb 14, 2024Guru - Experienced User
FURRYe38 is correct in that it should work with pretty much anything that has an ethernet connection.
The question is what settings are needed.
what modem/gateway is it from the ISP?
Some can be put in passthrough/modem only mode and allow you to direct connect the orbi to it.
Some can have the orbi's IP address into their dmz.
And others need the orbi put in access point mode. All depends on what specific gateway you have
