dianetrotter
Mar 07, 2021Aspirant
ORBI20, 40 or 50 Which should I buy?
Using the Orbi199 The internet disconnects when I leave it idle for more than an hour. Sometimes it disconnects while I am using it. I reboot at least 7 times a day. Technicall support has helped at...
Mar 08, 2021Guru - Experienced User
From my eperiences Orbi AX and Orbi AC are working well. Not everyone on Orbi AC has DNS issues. If they did, there would a ton more posts about like there is on Orbi AX. Lets keep this two models separate.
