steve37066
Apr 27, 2022Tutor
ORBI350 continuely resynching
ORBI350 with 1 satellite, both on firmware v4.4.0.10_2.10.63. Router is in APmode. Recently I find the satellite is very often in synchronising mode. That is to say that the white LED starts flashi...
- Apr 28, 2022
I'd try 1-6-11.
Not sure what you're options are for 5ghz and I don't have a dual band version to test with
Apr 27, 2022Guru - Experienced User
Have you tried moving the satellite around? or closer?
Maybe there is a sync issue.
steve37066
Apr 27, 2022Tutor
Hi,
Have shifted the satellite about 6ft closer (router and satellite are now less than 30ft apart) but still having the same problem. Note that this has been happening only in the last week or so after about three months of perfect functioning. There hasn’t been any changes in the original configuration.
