steve37066
Apr 27, 2022Tutor
ORBI350 continuely resynching
ORBI350 with 1 satellite, both on firmware v4.4.0.10_2.10.63. Router is in APmode. Recently I find the satellite is very often in synchronising mode. That is to say that the white LED starts flashi...
- Apr 28, 2022
I'd try 1-6-11.
Not sure what you're options are for 5ghz and I don't have a dual band version to test with
steve37066
Apr 27, 2022Tutor
Hi,
Have shifted the satellite about 6ft closer (router and satellite are now less than 30ft apart) but still having the same problem. Note that this has been happening only in the last week or so after about three months of perfect functioning. There hasn’t been any changes in the original configuration.
Apr 27, 2022Guru - Experienced User
Have you tried changing wifi channels?
the 350 series is dual band without the dedicated backhaul. maybe there's interference
- steve37066Apr 27, 2022Tutor
No, I haven’t tried that. Can it be done through the Orbi app or do I need to connect in some other manner?
- plemansApr 28, 2022Guru - Experienced User
I'm pretty sure you can do it through the app (haven't tried in a while).
I usually just do it through the browser.
- steve37066Apr 28, 2022Tutor
No through the app can't find channel setup.
Logged in to router with browser. Now it is in auto select. I see that there's a choice of 13 channels....which should I go for?
Do I have to do this on the satellite as well or only on the router?
thanks
