LLDUSA
Oct 13, 2021Aspirant
Orbi6 AX6000 - Not connecting as a star network - both satellites hard wired back haul
I have an Orbi WiFi 6 Router AX6000 system. Both satellites are hardwired backhaul to the RBR850. For some reason - they are no longer set-up in a Star Network and now one of the satellites ...
- Oct 13, 2021
There we go.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. đĄ
Oct 13, 2021Guru - Experienced User
Ya Daisy Chain is only over wireless connections, not wired.
