LLDUSA
Oct 13, 2021Aspirant
Orbi6 AX6000 - Not connecting as a star network - both satellites hard wired back haul
I have an Orbi WiFi 6 Router AX6000 system. Both satellites are hardwired backhaul to the RBR850. For some reason - they are no longer set-up in a Star Network and now one of the satellites ...
- Oct 13, 2021
There we go.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Oct 13, 2021Guru - Experienced User
You have both satellites hardwired into the router?
What is telling you its in a daisy chain setup?
And if its hardwired, even if its daisy chained, it should still perform the same because its all going through the ethernet connection
LLDUSA
Yes - thanks - both satellites are hardwired back into the RBR850. I find it strange that now one of the satellites (although both being hardwored back into the RBR850) show going through the other satellite. It always was set-up as a Star network.
Thanks in advance for your help!
This is from the RBR850This is from the Orbi6 App
- plemansOct 13, 2021Guru - Experienced User
Photos have to be approved by a moderator. And it can take a while.
If you click on "choose file" and attach them individually, we can see them right away.
