LLDUSA
Oct 13, 2021Aspirant
Orbi6 AX6000 - Not connecting as a star network - both satellites hard wired back haul
I have an Orbi WiFi 6 Router AX6000 system. Both satellites are hardwired backhaul to the RBR850. For some reason - they are no longer set-up in a Star Network and now one of the satellites ...
- Oct 13, 2021
There we go.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Oct 13, 2021Guru - Experienced User
Very Odd.
Ok, try this, disconnect the RBS thats turned OFF from the RBRs ethernet port.
Select the Disconnect button for the 1 RBS thats turned OFF on the RBRs web page to remove it. Will get this added later.
Power OFF both RBR and farthest RBS for 5 minutes, then back on with the RBR first then farthest RBS...
LLDUSA
Will - to be clear - the one that is the farthest - even know they are both connected via ethernet?
Thanks.
- FURRYe38Oct 13, 2021Guru - Experienced User
Yes.
Trying to see if the farthest RBS can show on RBR correctly connected. It should show connected to the RBR and not a blank spot...
Can to be sure, each one of the RBS is directly connected to the back of the RBR.
Let us know what you see after removing the nearest RBS from the RBRs web page and powering OFF the RBR and farthest RBS then back ON.
- LLDUSAOct 13, 2021Aspirant
Ok - done.
RBR is back up and the one fartheset is connected - see attached.
And App...
When should I try and add back the second RBS and what is the process?
Try turning ON the nearest RBS...
Keep the RBRs web page open. Exit from the Orbi app fully.
Progress! The RBR webpage showing both RBSs connected. (see attached file)
May I check the App?
There we go...
Yes.
Success (app image attache)
Thank you VERY VERY much!!
There we go.
Enjoy. 📡
