hmvm12345
Jan 27, 2024Tutor
Orbi6 Intermittent Performance Degradation
I've had an Orbi 6 system (router + 2 satellites) for almost 2 years now. Worked like a charm until about 2 months ago. Since then at times, I can see painfully slow connectivity on my laptop, connec...
Jan 27, 2024Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
Armor, Smart Parental Controls or Circle, Traffic Meter.
You behind on FW as well:
hmvm12345
Jan 27, 2024Tutor
Thanks a lot, I'm going to work through a few of these. The FW part surprised me, but now I'm going through the manual upgrade process. Btw, I don't know if you have the ability to do this, but it'd be great if Netgear updated the instructions for the manual upgrade. Most of it just seems to be 'download file, upload and install', but the file you download is a zip and it's rejected by the UI without much of a message. Somewhere else I read that the system is expected a .chk file, so that made me unzip and I'm now successful.
- FURRYe38Jan 27, 2024Guru - Experienced User
I'm planning on asking NG to update there KBs with what I posted here in the forums that gives better details and explanation of how to do a manual update. Glad it helped.
