hmvm12345
Jan 27, 2024Tutor
Orbi6 Intermittent Performance Degradation
I've had an Orbi 6 system (router + 2 satellites) for almost 2 years now. Worked like a charm until about 2 months ago. Since then at times, I can see painfully slow connectivity on my laptop, connec...
Jan 27, 2024Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
Armor, Smart Parental Controls or Circle, Traffic Meter.
You behind on FW as well:
hmvm12345
Jan 27, 2024Tutor
I'm now on the newest firmware on all 3 devices.
I'm going to do another power reset as you've suggested.
House profile: urban rowhouse, 4 floors. Satellites in basement and 1st floor. Router on 2nd. ~3500 sq ft total. Orbilogin shows Backhaul status as 'Good'.
Enable AX is on for 2.4, 5 GHz. Both 2.4,5 are enabled. Channel frequency for 2.4 is auto, 5 is pinned to 36 (my tinkering).
Additional features are off.
Do you have a good test to suggest I run between these debug stages?
