jautn
Sep 25, 2022Tutor
ORBI750 + Satellite not providing internet connection
I purchased a used ORBI 750 Router + 1 Satellite kit in July. I performed factory reset and installed the device and set up settings. So far have never had any issues up until this past week. I run...
- Sep 26, 2022
jautn wrote:
Nothing seemingly changed after both test and apply.
I initially thought it might be incompatibilities with ISP and my hardware but via Charters compatibility page, they should talk to each other without a problem.Can it be that the ISP "blocked" Orbi's MAC address! I've seen this before. For troubleshooting purpose, under "Router MAC Address" please choose "Use Computer MAC address" (if you're accessing Orbi from a computer) or select "use this MAC address" and just copy the MAC address of one of your satellites, and click Apply.
jautn
Sep 26, 2022Tutor
Definitely a possibility and I'll go with that for now. Seeing how many issues people have with the ORBI systems, I have a checklist of troubleshoots to follow, this will make it to the top of the list for this time around.
Thanks so much for your help!
Sep 26, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
