Venturer51
Feb 27, 2025Tutor
Orbi750
Getting a privacy alert on my network. How do I resolve this issue?
KevinLiT
Feb 27, 2025NETGEAR Moderator
Hello Venturer51 ,
Thank you for providing that information!
The issue you are experiencing may be occurring because your Orbi network is not using the latest wireless password encryption (WPA3-Personal [SAE]). To resolve this issue please use WPA3-Personal as your password security options.
Please follow the instructions below to change the wireless password security encryption for your RBR750:
First, Navigate to orbilogin.com
Next, Select the wireless option
Now on the right, select WPA3-Personal [SAE] (Located under security options)
Then, select apply.
Best,
Kevin
Community Team
Venturer51
Feb 28, 2025Tutor
Setting is at wpa3 personal and still getting privacy alert. No alert when using guest network. Is this something I should worry about?
- plemansFeb 28, 2025Guru - Experienced User
No its apple saying you're not using private mac/ip address feature. on a home network, its fine.
- CrimpOnFeb 28, 2025Guru - Experienced User
Certainly easy to validate. Disconnect from WiFi. Enable feature. Connect to WiFi.
- KevinLiTFeb 28, 2025NETGEAR Moderator
Hello plemans,
It is true that Wi-Fi password encryption WPA2 is still sufficient because it uses AES instead of TKIP. However, that message usually shows up when it detects that the most recent security standards are not being used. This iOS feature was released in iOS 14 to help educate and protect users.
Best,
Kevin
Community Team
- FURRYe38Feb 28, 2025Guru - Experienced User
Also be aware that Apple implemented another mode in the Private Wi-Fi feature in iOS, FIXED is now an option. I Think this was to help elevate some issues users were seeing with some router systems having Randomized enabled and only other option was disabled with would cause a privacy alert on the phone when connected to any SSID signal, regardless if WPA3 was present or not.
The Randomizer would show the phone on the router systems connected pages as UNKNOWN. Users were bothered by this. I believe FIXED how shows the phone model host name correctly. I prefer to disable it entirely while I'm at home. Zero need for MAC Address modifications while at home.
