checkyourmirror
Jan 22, 2024Aspirant
Orbi960 and GS110MEX speed slow when using 2.5Gb Ethernets
When I connect my Orbi to my Netgear switch via 2.5Gb ports, the transfer speed from a wired Mac is about half when I use a 1Gb port between the two. My setup is simple for testing purposes, and I ha...
Jan 22, 2024Guru - Experienced User
Might try a different switch.
Does Mac directly connected to the 2.5Gb LAN port in back of the RBR show a expected 1Gb speed to your PC?
checkyourmirror
I don't have another switch easily available, and I did connect the Mac 1Gb into the Orbi and got the expected 1Gb speed.
