AtariPezman
Apr 17, 2023Aspirant
Orbi960 WAN Aggregation question
Hello, Could you clarify for me what Orbi's WAN aggregation is truly capable of? I've read the Netgear documentation and see it combines multiple network connections from your modem to your route...
Apr 18, 2023Guru - Experienced User
CrimpOn is correct. The Orbi won't support that.
Wan aggregation isn't dual wan support.
You'd want something that supports dual wan with failover/load balancing.
You'd be getting into business class routers for that.
Although, I think the edge router x line supports it but you'd have to check. They're fairly reasonable.
