Joplin
Jun 26, 2020Aspirant
Orbie RBK753 Stereo connection
Can Orbi RBK753 connect to a non-wifi stereo amplifier? Can it plug into the stereo using ethernet cable, to adapter, to RCA plug? Then I would use current Ipod to play music over wifi into stereo A...
Jun 26, 2020Guru - Experienced User
Not unless you install some forum of wifi/ethernet adapter to the non wifi/ethernet stereo. Something to look at amazon to see if there is such a thing.
Chuck_M
Jun 26, 2020Mentor
Sounds like your stereo is a non-networked non-digital device. If that is true, the answer is no.
Can you reply with the make/model of your stereo you are talking about?
- JoplinJun 26, 2020Aspirant
The stereo amp is a Yamaha R-S700,
- Chuck_MJun 26, 2020Mentor
Not a digital or networked Amp.
- JoplinJun 26, 2020AspirantThanks a lot for checking into that.
Even if I connect the router to the amp with cables and adapters, the music won't play?
I discovered 3' Ethernet wire that I can plug into a female adapter to RCA twin male plug. For this setup to work I would need a digital amp?
