JimTurkey
Aug 01, 2022Guide
orbilogin.com "admin" pop-up not there
My internet was getting a little slow and lagged at times. So, I went to at AT&T's website and used the "Restart Gateway" option. I have the Motorola BGW210-700. No problem! Internet is running fine!...
Aug 01, 2022Guru - Experienced User
Are you trying to access orbilogin.com or 192.168.1.1?
What browser are you using?
FYI, Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
I would try option #2 first.
- JimTurkeyAug 01, 2022Guide
- I am trying to access orbilogin.com
- I am using Safari
- I don't know what firmware I have. How would I check that?
- Seeing that a double NAT was ill-advised, I thought I set it up as an access point (several months ago) but I'll do the troubleshooting tips and see if I can fix it. Hindsight being 20/20, I wish I'd tried logging into orbilogin.com prior to "Restarting the Gateway"
- FURRYe38Aug 01, 2022Guru - Experienced User
Try Firefox or Opera and 192.168.1.1 and see if you can access the RBRs web page.
No luck on Firefox. It went to the same netgear page referenced in my original post.
- plemansAug 02, 2022Guru - Experienced User
- I am using Safari
If you set it up in access point mode already, then log into the att router and look under its attached devices page (or equivalent). The ATT router assigns an ip address to it and its not going to be using the default ip addresses. So find what it assigned to it and use that to access it.
- JimTurkeyAug 13, 2022Guide
UPDATE: So oddly enough, I attempted to go back into orbilogin.com a minute or two ago ... SUCCESS! I don't know what changed but it's working for me now.
So I'm logged in there. With my BGW210, what settings should I have in orbilogin.com? And what settings should I have on the AT&T side of things? I just want to make sure everything is running correctly.
Thanks!
