JimTurkey
Aug 01, 2022Guide
orbilogin.com "admin" pop-up not there
My internet was getting a little slow and lagged at times. So, I went to at AT&T's website and used the "Restart Gateway" option. I have the Motorola BGW210-700. No problem! Internet is running fine!...
JimTurkey
Aug 01, 2022Guide
- I am trying to access orbilogin.com
- I am using Safari
- I don't know what firmware I have. How would I check that?
- Seeing that a double NAT was ill-advised, I thought I set it up as an access point (several months ago) but I'll do the troubleshooting tips and see if I can fix it. Hindsight being 20/20, I wish I'd tried logging into orbilogin.com prior to "Restarting the Gateway"
Aug 01, 2022Guru - Experienced User
Try Firefox or Opera and 192.168.1.1 and see if you can access the RBRs web page.
- JimTurkeyAug 01, 2022Guide
No luck on Firefox. It went to the same netgear page referenced in my original post.
- FURRYe38Aug 01, 2022Guru - Experienced User
So 192.168.1.1 doesn't work? Does 10.0.0.1 work?
If not, I would disconnect the RBR from the ISP Modem and disconnect ALL other LAN devices from the RBR accept for 1 wired PC.
Factory reset the RBR by pressing the reset button for 20 seconds then release. Once the RBRs front LED starts pulsating WHITE, try accessing the RBRs web page at HTTP and 192.168.1.1.
Be sure to clear out ALL browser caches before.
