jfdorbi
Jan 04, 2021Tutor
orbilogin.com does NOT ask for username/password at login
While the ios app asks for an admin u/p at login, the orbilogin.com site does not. Seems like it should. Is this normal behavior? I have gone through the set password function on the web inte...
- Jan 10, 2021
After a factory reset and reinitialization, the u/p login prompt now shows up at orbilogin.com and the orbi app.
Again, thanks for all suggestions.
Mikey94025
Jan 10, 2021Hero
jfdorbi wrote:I have arrived at the same result logging in through Safari on several Macs and ios devices, Chrome on a Mac, and Edge on a Windows10 VM.
Not quite sure where to go from here. Maybe reset the Orbi system and try again?
Just as a sanity check, you are supposed to be presented with a login dialog when you browse to the web admin interface, even while you are on your wifi netwrok, correct?
Thanks for listening
If you use the browser app on your phone, like Chrome on iPhone, and visit orbilogin.com then does it prompt you for a password? Also try the IP address of your Orbi, e.g., for me this is http://192.168.1.1/
It does seem like you've tried a variety of browser to eliminate that you have some custom "save-my-passwords-for-me-so-I-autologin-next-time" option setup. That's the usually reason people see what you describe. Do you have another Mac or Windows login to try with one of the desktop browsers?
Yes, whenever I go to http://orbilogin.com I get a browser popup asking for Username and Password. See attached screen shot.
