discgolf01
May 16, 2022Tutor
Orbilogin.com/net "Refused to Connect"
Hi All, Orbi RBR750, 2 satellites Nighthawk CM1100 modem Issue: Has been working fine since mid January up until last week. When trying to connect to admin page, using either orbilogin.com...
May 16, 2022Guru - Experienced User
- discgolf01May 16, 2022Tutor
Thank you for the quick reply. Frustrating to see Netgear's answer is a factory reset, was trying to avoid that as I had a lot of customizing done and a decently old back up settings file (I know, my fault). Maybe I'll let it go for a while to see if they push anything out and it starts working without a factory reset. Arrrgh.
- FURRYe38May 16, 2022Guru - Experienced User
Might contact NG support and see if they can help with out a reset.
