Meddyb's avatar
Meddyb
Orbilogin issue
Hello All, I have recently bought an Orbi AX6000 ( RBR850 + RBS852) I never could connect to the orbilogin.com or .net, nor via the Ip address as I am always prompted with the hereunder message no ...
  • Mikey94025's avatar
    Mikey94025
    Jan 26, 2022
    Meddyb wrote:
    Thanks Mikey,
    I can't reset now as I am working from home, I'll do that later in the week hopefully
    The result as stated in the very first message is the same
    I just tried again on http://10.0.0.1 and same issue
    If you see "Router Password Reset" screen then it means you entered the wrong Username/Password.  If your browser is not displaying a popup dialog to enter Username and Password before showing the page, then something on your PC is preventing it from appearing or blocking the input.
    Have you tried going to http://10.0.0.1 on another device, like your phone's browser?
