n1david
Nov 01, 2021Tutor
Orbilogon stuck in password reset loop
Newly-installed Orbi RBK752 system configured using the iOS app. Now trying to access Orbilogin.com to get access to advanced settings. When I enter Orbilogin.com on my Mac, I get taken to a Rou...
cheddabobb
Apr 14, 2022Aspirant
Having the same issue. Netgear doesn't realize it's just average users who aren't IT geniuses using their products. You would think something like being able to log into orbi settings would just work. I have the SAME issue where it's stuck in a loop. I would have to purchase support service in order to get assistance on one stupid issue.
Apr 14, 2022Guru - Experienced User
Wire connect a PC to the router and factory reset the router using the back push pin button. Hold it in for 15 seconds then let go. Power OFF the ISP modem for 30 seconds than back on. Wait for the WHITE led to slowly pulsate on top of the RBR, then log in to orbilogin.com using a web browser and walk thru the setup wizard. This time write down all important information for safe keeping later on.
