sigurbg
Sep 04, 2023Follower
OrbiRBR750 does not light up
This happened to me as well. The router does not work, boot up. Unable to connect to it.
Unfortunately, I am just past the 2 year product support by 1 month.
1 Reply
Try swapping Power adapters with one from the RBS to see if this does anything?
Try a 15 second press on the reset button?
Try a 30-30-30 reset on the RBR with it disconnected from the ISP modem?
IF this all fails, the RBR needs replacing.
