scottpritchard
Oct 05, 2022Aspirant
OrbiRBR750 shows no internet and purple light on some devices but most devices work
I have cable internet and upgraded the modem and went from 400mbs to 1gbs. When they upgraded, they changed the modem and the with the new modem I cannot turn off the wifi signal from that modem. The...
Oct 05, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
scottpritchard
I will get all that information soon. But I noticed that its any devices connected to Wifi6. I turned off the AX connection and I'm going to test and see if that is what is disconnecting.
