scottpritchard
Oct 05, 2022Aspirant
OrbiRBR750 shows no internet and purple light on some devices but most devices work
I have cable internet and upgraded the modem and went from 400mbs to 1gbs. When they upgraded, they changed the modem and the with the new modem I cannot turn off the wifi signal from that modem. The...
iyang
Oct 06, 2022NETGEAR Expert
Hi scottpritchard ,
What's connected devices had the issue ?
Can you share the connected devices' model name ?
Thanks.
scottpritchard
Oct 11, 2022Aspirant
Its been devices that use WIFI6 (mostly cell phone). I disabled WIFI6 through the Orbi setup page and I haven't had a problem since. Maybe there is an issue with the WIFI6 losing internet with 1 gig speeds? IDK. I replaced the modem and it still had the issue so that's why I turned off WIFI6 or the AX settings. IDK
- FURRYe38Oct 11, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
