jreid22
Mar 01, 2021Aspirant
OrbiRBR852 losing wifi frequently
I'm at my wits end with the device. It frequently disconnects and reconnects wifi to multiple macbooks in the home. I have the RBR852 with a satelite. Speeds are great when it works. Wired devices ha...
Mar 02, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Armor, and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Set CTS to 2347. Save settings and reboot the router and satellite(s).
