ptyzx
Feb 21, 2020Aspirant
Orbis RBK852 -need to bridge from router to home theater devices 25 feet away
Want to purchase the RBK852 (or RBK853j) for my soon to be installed 1 gig service from Spectrum. My home is 2 stories and approx 2500 sq ft. Current system: My home theater is in the same ro...
ptyzx
Feb 26, 2020Aspirant
That sounds like the perfect setup. Unfortunately, running cat 6 cable is not an option for me.
Thanks for the help.
Feb 27, 2020Guru - Experienced User
You can try Power Lines and see if this would work for you then.
After cabling installation also can be done as well if at some point you wanted to run LAN cables in a existing home that doesn't have LAN cables in wall.
Good Luck.
