LuckyClover13
Nov 26, 2021Aspirant
Orbi/Satellite vs Nighthawk/Extender for gaming
Happy holidays! I posted a previous thread on the Nighthawk community, and am looking for more insight from the Orbi community. I’m looking to cover 2700 sqft of home, and thinking of switching from X...
- Dec 05, 2021
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Nov 26, 2021Guru - Experienced User
Best connection for gaming is ethernet connected to the RBR. Unless you can get the RBS ethernet connected to the RBR. Placement and distance between the RBR and RBS is important.
LuckyClover13
That’s makes sense. How much distance is advised from each satellite? I have not found a clear answer on that. I’m looking at about 40 ft distance between downstairs and upstairs.
- FURRYe38Nov 26, 2021Guru - Experienced User
30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡40 will work great...
- LuckyClover13Nov 26, 2021AspirantVery helpful thank you for the information! Ordered, and will be giving it a try next week.
- FURRYe38Nov 27, 2021Guru - Experienced User
