Rudolphy
Jun 25, 2021Apprentice
Orbo AX4200 (RBR750) - connection strenght
Hello dear forum, Since I now have one or the other ax-capable device, I switched to the AX version RBK750 after three years of Orbi RBK50. I operate the devices in AP mode. In AP mode, you can h...
Jun 25, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
- RudolphyJun 25, 2021Apprentice
Thanks for your feedback. It is not about what the optimal settings are, I have made enough experience from the last three years with my RBR 50.It's really about whether in the AX series, since you can make there in AP mode hardly WLAN settings, The system first time long necessary to analyze the connected devices, traffic, and so on, to then make the optimal utilization. So it seemed to me in any case. Or was it a coincidence that the connection strengths improved across all devices, while the external conditions remained the same.
