phpposter
Feb 16, 2024Follower
Orbo AX6000 Mesh System - 2.5 Gigabit Ethernet Port
Hi all, I'm considering purchasing an Orbi AX6000 mesh system. For practical reasons however, I would like to know whether I need to connect my router / modem into the 2.5 Gbps WAN port to achieve i...
Feb 17, 2024Guru - Experienced User
The LAN ports on the 8 series Orbis are limited to 1Gb max connection rates, so you'll never see anything much past 900Mpbs on the LAN side. If you have 2.5Gb ISP speeds and want to see those speeds on the LAN side, you'll need a Orbi 9 series system which do have 2.5Gb Rated LAN ports.
phpposter wrote:
Hi all, I'm considering purchasing an Orbi AX6000 mesh system. For practical reasons however, I would like to know whether I need to connect my router / modem into the 2.5 Gbps WAN port to achieve internet connectivity, or can I simply use one of the spare Gigabit LAN ports? I intend on using the 2.5 Gbps WAN port to connect to a 2.5 Gbps Managed switch which is connected to my server and various other high-bandwidth devices. My router / modem however, can only out-put Gigabit speeds / ~100mbps internet speeds.
Thanks in advance!
