bwang
Mar 13, 2021Aspirant
orbt setup, no connection to internet
I have Verizon fios and just purchased the Orbi RBK754. I am trying to set it up connected directly to the Verizon ONT. Ethernet port is active on the ONT. And I released DHCP on the Verizon Quant...
Mar 18, 2021Guru - Experienced User
Try setting up the RBR with out it being connected to the ONT. You can manuall set it up and walk thru the setup wizard with a wired PC and web browser. Once you have it setup and configured. Power OFF the ONT and RBR. Connect the RBR to the ONT and power it ON. then power ON the RBR. Use the RBRs web page to check for the Internet status on the basic tab.
bwang wrote:I have Verizon fios and just purchased the Orbi RBK754. I am trying to set it up connected directly to the Verizon ONT. Ethernet port is active on the ONT. And I released DHCP on the Verizon Quantum Gateway router before shutting it down based on suggestions I read so far. However, the Orbi setup reaches the last step which is checking for internet connection. It says "no internet conenction found". Any additional suggestions on why this is happening?
bwang
Mar 18, 2021Aspirant
Thanks for all the help. Connecting a PC to the router and use the Web setup did the trick. The mobile app setup process was well designed and very simple, but just does not work in this situation.
- FURRYe38Mar 18, 2021Guru - Experienced User
Glad you got it up and running. Ya, once the system is setup. the orbi app can be used to review the system and see whats connected and such. Not alot of features to the app. You can disable some devices and run a speed test. I don't use it much.
Be sure to run a back up configuration to file for safe keeping. Saves time if a reset is needed. Enjoy. :smileywink:
bwang wrote:Thanks for all the help. Connecting a PC to the router and use the Web setup did the trick. The mobile app setup process was well designed and very simple, but just does not work in this situation.
- vajimMar 18, 2021Master
FURRYe38 wrote:Glad you got it up and running. Ya, once the system is setup. the orbi app can be used to review the system and see whats connected and such. Not alot of features to the app. You can disable some devices and run a speed test. I don't use it much.
The orbi app is useless
