Axl2020
Feb 10, 2022Aspirant
Orby 750 can't assign IP to guest wifi
Hello, my orby RBR750 with Firmware Version V4.6.5.14_2.0.54 and with attached 2 satellite is cofiguret as a router. I've set up the guest wifi. The problem seems that on this wifi the dhcp don't as...
- Feb 10, 2022
Has a factory reset and setup from scratch been performed with a ethernet connected PC and web browser?
Even if you disable WiFi Private Address on the iPhone, it will not connect?
If you disable the security mode and set to NONE, does anything connect to GN? Re-enable WPA2 after testing this.
What mode is the modem working in? Router or bridged?
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Feb 10, 2022Guru - Experienced User
What devices are you connecting to the Guest Network?
What devices have you connected to the GN?
I believe the IP address will differ from the main LAN network IP address pool.
Axl2020
I've tryed to connect my iPhone (ios 15.4) and the macbook Pro with Montery. I've tryed also with an android and a win pc.
I'm unable to connect any devices.
The Orby is connect to a Vodafone Station 6 (firmware:XF6_3.0.17.04, HW version RHG3006 v1).
- FURRYe38Feb 10, 2022Guru - Experienced User
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop- Axl2020Feb 10, 2022Aspirant
Thanks, I've disabled the wifi protection and it works. After reenabled it works again.
Thanks for suggestion.
Max
Interesting. Wondering if the RBR or security mode got into some bad state.
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
- CrimpOnFeb 10, 2022Guru - Experienced User
Axl2020 wrote:
I've tried to connect my iPhone (ios 15.4) and the macbook Pro with Montery. I've tryed also with an android and a win pc.
Could you please elaborate on "what happens"?
- Does the guest WiFi name (SSID) appear on the list of available WiFi systems on all of these devices?
- When you enter the guest password, what happens?
Does the device say, "Connected"? - When you look at the device Network settings, do they show the name of the guest WiFi, a "link rate", but no IP?
