Axl2020
Feb 10, 2022Aspirant
Orby 750 can't assign IP to guest wifi
Hello, my orby RBR750 with Firmware Version V4.6.5.14_2.0.54 and with attached 2 satellite is cofiguret as a router. I've set up the guest wifi. The problem seems that on this wifi the dhcp don't as...
- Feb 10, 2022
Has a factory reset and setup from scratch been performed with a ethernet connected PC and web browser?
Even if you disable WiFi Private Address on the iPhone, it will not connect?
If you disable the security mode and set to NONE, does anything connect to GN? Re-enable WPA2 after testing this.
What mode is the modem working in? Router or bridged?
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Axl2020
I've tryed to connect my iPhone (ios 15.4) and the macbook Pro with Montery. I've tryed also with an android and a win pc.
I'm unable to connect any devices.
The Orby is connect to a Vodafone Station 6 (firmware:XF6_3.0.17.04, HW version RHG3006 v1).
Feb 10, 2022Guru - Experienced User
Couple of options,
- Axl2020Feb 10, 2022Aspirant
Thanks, I've disabled the wifi protection and it works. After reenabled it works again.
Thanks for suggestion.
Max
- FURRYe38Feb 10, 2022Guru - Experienced User
Interesting. Wondering if the RBR or security mode got into some bad state.
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
