donawalt's avatar
donawalt
Hero - Experienced User
Aug 04, 2024
Orientation of Orbi routers and satellites
Hi, what is the latest guidance on where the Orbi devices should be faced? I have read some stuff online, mainly old, that says the "flat" part should be faced into the center of the house - but Orbi 800 and 900 series don't have a "flat" part that I see lol. It also said top and bottom get weaker signals. But again, this was all old., at least 4 years old or more - meaning older Orbi models.
The 970 and 770 series Tech Spec sheets say:
  • Exceptional Whole-home Mesh WiFi—Elegant new design and high-performance antennas provide 360° WiFi coverage throughout your home, no matter the layout, from the front door to the backyard.
However, the 960 and 860 series Tech Spec sheet do not reference 360° WiFi coverage.
So - Am I correct that it doesn't matter where the Orbi devices face if you have 970 or 770? And in the case of 960 or 860, what's the current guidance there?
Thanks!
  • FURRYe38's avatar
    All signals emanating form the units are 360.
    • donawalt's avatar
      donawalt
      Thanks FURRYe38 - so why don’t the tech spec sheets for the 960 and the 860 series discuss the 360° at all?
