donawalt
May 18, 2021Hero - Experienced User
Orientation of RBR850 and RBS850
Is there documentation or pictures of the best way to face the rbr850 and rbs850? I assume the front faces the center of the house if it's in a corner for example, but I was not sure based in how the...
May 24, 2021Guru - Experienced User
I believe the orientation isn't very important. Orbi systems seems to be 360 degrees of signal broadcast.
