AColdMilo
Mar 25, 2025Aspirant
Orvi RBR760 connectivity issues from internet to router
Trying to understand what the symbols on the orbi app network map mean here. It's not an issue with my ISP. I'm repeatedly having this issue and then having connectivity issues with my devices. Power ...
May 07, 2025Guru - Experienced User
Got a cheap unmanaged switch sitting around? I've seen a few posts on here with Nokia ONT's (are they just an ONT? Their specs lead me to believe they have some traffic modeling) that had issues. Some were fixed with simply using an unmanaged switch in between them.
You might check with the ISP to see if they need a specific vlan setup for the ONT.
