dishonorablebas's avatar
Mar 07, 2025
Outdoor camera connects to Orbi RBR 80 feet away rather than RBS 8 feet away
I have an outdoor camera that used to connect to my RBS 850 that is just 8 feet away, next to a window inside a bedroom.  This is the behavior that I expected, using the Orbi mesh.   Then a few wee...
  • dishonorablebas's avatar
    dishonorablebas
    Mar 07, 2025
    Bingo !  That was it.
    It seems that the outdoor camera did connect to the router during the factory reset, and kept its allegiance to this connection after the satellites were brought-up.
    So, lesson learned is... When performing a factory reset on an RBR that has satellites, make sure that any device that is likely to be considered a stationary device (like a camera) is powered down/off before the reset is started.  Then, once the router is back online, and all the satellites have been brought up and synced, THEN power up/on any cameras or other stationary-type devices.  These devices will likely connect to the preferred/optimal satellite (or router, if applicable).
    Special thanks to FURRYe38 and CrimpOn for helping to solve this issue.
