dishonorablebas
Mar 07, 2025Aspirant
Outdoor camera connects to Orbi RBR 80 feet away rather than RBS 8 feet away
I have an outdoor camera that used to connect to my RBS 850 that is just 8 feet away, next to a window inside a bedroom. This is the behavior that I expected, using the Orbi mesh. Then a few wee...
- Mar 07, 2025
Bingo ! That was it.
It seems that the outdoor camera did connect to the router during the factory reset, and kept its allegiance to this connection after the satellites were brought-up.
So, lesson learned is... When performing a factory reset on an RBR that has satellites, make sure that any device that is likely to be considered a stationary device (like a camera) is powered down/off before the reset is started. Then, once the router is back online, and all the satellites have been brought up and synced, THEN power up/on any cameras or other stationary-type devices. These devices will likely connect to the preferred/optimal satellite (or router, if applicable).
Special thanks to FURRYe38 and CrimpOn for helping to solve this issue.
CrimpOn
Mar 07, 2025Guru - Experienced User
dishonorablebas wrote:
I am considering to unplug that camera from its battery, and then try to sync it with the preferred satellite, in close quarters.
That sounds like a wonderful experiment. There is a hypothesis that WiFi devices have different internal programming.
- Devices that are intended to be mobile appear to be programmed to search constantly for a "better connection".
- Devices that are expected to remain in one place may be programmed to search for a WiFi connection that they know the password to, connect to it, and stop looking. When a mesh system is rebooted, the router typically begins broadcasting the WiFi SSID before the satellites. If a device detects the router first, it may connect to the router before the satellite signal is available. Restarting the WiFi device is a method to determine if this is happening.
Before moving the camera, I suggest restarting it in the current location.
dishonorablebas
Good suggestions. I think you are probably right, because when I factory reset the router, I did not unplug the outdoor camera battery, and this may have synced that device with the router, rather than the satellite(s).. I'll unplug it (in-place) shortly, and see what happens.
- CrimpOnMar 07, 2025Guru - Experienced User
Please comment on the results. Over the years, "Device connects to wrong Orbi unit" has been one of the top issues. Users plead for a method to force devices to connect where they think best (a feature apparently provided by some brands of WiFi router) and Netgear's response has been consistent: It's up to the device to pick the connection, not the WiFi system.
- dishonorablebasMar 07, 2025Aspirant
