Orbi_Guelph
Jul 23, 2023Aspirant
Outdoor Extender Options
I bought Netgear Orbi RBK853-100CNS Tri-band Mesh WiFi 6 System from Costco. Love it. I am not looking to extend wifi coverage outdoors. Since the RBS50Y looks like it is discontinued, what other opt...
- Jul 23, 2023
The RBK853 — Orbi WiFi 6 System AX6000 consists of (1) Orbi Router (RBR850) + (2) Orbi Satellites (RBS850).
schumaku
Jul 23, 2023Guru - Experienced User
Consult the Which Orbi routers and satellites are compatible? list.
Orbi_Guelph
Thanks for link. It is not listed.
- schumakuJul 23, 2023Guru - Experienced User
- Orbi_GuelphJul 23, 2023AspirantThank you.
