Anzenchitai
Jul 01, 2022Aspirant
Outside WiFi extender for RBKE963
Now I m using the RBKE963 WiFi6E system. I am looking for a compatible Outside Extender for the 5Ghz WiFi in my Garden to the barn. Which products are compatible with my system? I would like to have the product advisor to help me out here.
Thanks in advance.
1 Reply
Only outdoor satellite that may work is the RBS50Y if used in Extender mode. Natively it's in Orbi mode and works with the 20, 30, 40 and 50 series Orbi systems. It works with AX systems if its loaded with Extender mode FW.
Otherwise NG doesn't have a newer AX or AXE outdoor unit currently. No idea if or when they may come out with on either.One possible alternative. I have seen others post about using a outdoor enclosure and they've put in this case a indoor satellite:
