AngeloUCF
Feb 09, 2024Aspirant
Packet loss and intermittent internet on RBR750
Hi, I am experiencing packet loss on my home network, making some devices unusable. This is the second time I've experienced this. The first time I ended up replacing the router. I initially boug...
Feb 09, 2024Guru - Experienced User
How are you testing for packet loss?
Wired or wireless device? Wired is preferred.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
️Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Any Wifi Neighbors near by? If so, how many
Armor, Smart Parental Controls or Circle, Traffic Meter.
AngeloUCF
This is happening from my desktop when directly connected to the router and no satellites connected. All wifi devices experiencing the same issue.
How are you testing for packet loss? using cmd line "ping -t google.com"
Wired or wireless device? Wired is preferred. Both
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? It's my own Netgear modem I bought when I purchased the mesh system originally. I don't have the model as I am at work now. Issue does not occur when hardwired directly to the modem.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended. I will check this.
What is the size of your home? Sq Ft? 2 floors, 3500sqft
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS️ to begin with depending upon building materials when wired or wirelessly connected. I have the router in my office on the 2nd floor and I am hardwired directly to it. Satellites are pretty far away from each other. All downstairs on opposite sides of the house.
️Does this happen with the RBS turned OFF? Yes
Does this happen with both wireless and wired devices? Yes
What channel configurations are currently set on the router? 2.4 - Auto, 5 - 40
Any Wifi Neighbors near by? If so, how many 3-4
- CrimpOnFeb 09, 2024Guru - Experienced User
What is the difference in packet loss between the computer connected directly to the modem and the computer wired to the Orbi RBR750 router?
Is this phenomenon constant, or does it vary during the day?
Are there any devices on the local network that respond to ICMP ('ping')? Is the same sort of packet loss observed when pinging them?
- AngeloUCFFeb 09, 2024Aspirant
The packet loss is 0 when connected to the modem directly vs usually 30-75% when connected to the router. It is constant and doesn't stop intraday. I haven't tested ICMP but some wifi devices work in a limited fashion and other wifi devices don't work at all. Computer pages load slowly and sometimes time out but sometimes load fully, although slowly.
