Zipsy's avatar
Zipsy
Packet Loss
Recently the orbi has been really bad and slow even when connected via ethernet. The packet loss is extreme and the ping spikes are great as well. It works fine and then packet loss/stability is poor for a while. Makes it so the wifi is slower and sometimes won't even load. Any way to fix?
  • FURRYe38's avatar
    What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
    Armor, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
    Be sure your LAN cables are of good quality. CAT6 is recommended and to run all the same CAT version in cabling between devices and networking devices.
    • Zipsy's avatar
      Zipsy
      The model is a RBR750 with and the internet provider is comcast. The modem is also working fine since pinging the gateway is good. The wifi also sometimes doesn't work, in that the wifi sometimes cuts out saying that there is no internet and the satellites say something is wrong. The firmware is also updated.
      • FURRYe38's avatar
