GWild
Feb 27, 2021Guide
Page-Not-Found delay
Just upgraded from a CBK40 to a CBK752 (AC to AX). Pretty much aligned all settings the same as much as possible so the new kit would be plug and play with the rest of the network and clients. Ma...
- Mar 12, 2021
CBK752 Kit returned for full refund. Problem solved.
Feb 27, 2021Guru - Experienced User
This on Sparklight?
What FW version is on the CBR750?
- GWildFeb 27, 2021Guide
Sparklight, latest available firmware.
Status: Model Name Device Name Current Firmware Version Status Router CBR750 CBR750 V3.2.16.18 No New Firmware Available Satellite RBS750 Orbi Satellite-1 V3.2.16.22 No New Firmware Available Pretty disappointing, really. How hard can it be to make protocol stacks work propertly these days.
Then again, is the AX spec even approved yet? So silly me buying something before the ink is even dry.
- FURRYe38Feb 27, 2021Guru - Experienced User
Something to contact NG support about. Others are seeing this issue as well with the RBK AX system for those that are experiencing it. I for one have not seen this since I got my Orbi AX back in 2019. Seen other issues, just not this one. However, I use CM and CAX series modems on SparkLight.
Seems mostly happening with users with gateway ISP modems as well. Your the first i've on on same ISP with this issue.
Contact NG support and let them know what your seeing. Have then collect your debug logs as well. This needs to be addressed by NG. Nothing the forums can do about it.
Good Luck
One thing to try, setting up IPv6 6to4 DNS configurations on the CBR750...
I set manual IPv4 DNS and IPv6 6to4 DNS configurations on my RBR750 since I believe Mstrbig mentioned trying this on his system. Seem to help some.
Something to review and try:
