GWild
Feb 27, 2021Guide
Page-Not-Found delay
Just upgraded from a CBK40 to a CBK752 (AC to AX). Pretty much aligned all settings the same as much as possible so the new kit would be plug and play with the rest of the network and clients. Ma...
- Mar 12, 2021
CBK752 Kit returned for full refund. Problem solved.
GWild
Feb 27, 2021Guide
Sparklight, latest available firmware.
Pretty disappointing, really. How hard can it be to make protocol stacks work propertly these days.
Then again, is the AX spec even approved yet? So silly me buying something before the ink is even dry.
Feb 27, 2021Guru - Experienced User
Something to contact NG support about. Others are seeing this issue as well with the RBK AX system for those that are experiencing it. I for one have not seen this since I got my Orbi AX back in 2019. Seen other issues, just not this one. However, I use CM and CAX series modems on SparkLight.
Seems mostly happening with users with gateway ISP modems as well. Your the first i've on on same ISP with this issue.
Contact NG support and let them know what your seeing. Have then collect your debug logs as well. This needs to be addressed by NG. Nothing the forums can do about it.
Good Luck
