FusionDragon76
Nov 10, 2023Aspirant
Pairing Modem to router
hello i would to know if it is possible to sync a modem orbi to a router orbi so that it uses the same network ssid and password so like the orbi cbr 750 to a rbr850
- Nov 10, 2023
No. The CBR can't connect to the RBR and vs versa. They are independent systems and wifi from each other.
Nov 10, 2023Guru - Experienced User
Not possible.
One can put the CBR into modem mode and use it as a modem and then connect the 850 series router to the CBR:
https://kb.netgear.com/27191/How-to-set-the-cable-modem-router-to-be-on-modem-only
FusionDragon76
so its not possible for one network ssid and password with it
- FURRYe38Nov 10, 2023Guru - Experienced User
- FusionDragon76Nov 10, 2023Aspirant
Ah ok thanks for the help
đ
