FusionDragon76
Nov 10, 2023Aspirant
Pairing Modem to router
hello i would to know if it is possible to sync a modem orbi to a router orbi so that it uses the same network ssid and password so like the orbi cbr 750 to a rbr850
- Nov 10, 2023
No. The CBR can't connect to the RBR and vs versa. They are independent systems and wifi from each other.
FusionDragon76
so its not possible for one network ssid and password with it
Nov 10, 2023Guru - Experienced User
- FusionDragon76Nov 10, 2023Aspirant
Ah ok thanks for the help
- FURRYe38Nov 10, 2023Guru - Experienced User
đ
