BerniceAbrahsm
Apr 26, 2020Initiate
Parent control
Hi, I bought Orbi Wi-Fi 6 mesh AX6000 But I don’t know How and where can set up parent control if I don’t have circle device
Apr 26, 2020Guru - Experienced User
Can you set up Access Controls under Advanced Tab/Security/Access Control?
Circle isn't supported on Orbi AX currently.
- BerniceAbrahsmApr 26, 2020InitiateI can go to the access control but I cant control each user which day/ time can have Wi-Fi
- FURRYe38Apr 27, 2020Guru - Experienced User
We don't know if or when Circle will be coming to Orbi AX. Something to contact NG support about.
Might post here about this as well:
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
If you really need Circle, I would recommend the Orbi AC 50 series system. This supports Armor and Circle.
https://kb.netgear.com/000044718/Which-NETGEAR-routers-support-Circle-Smart-Parental-Controls
Not much else we can do here.
