rr20552
Feb 05, 2021Apprentice
Parental controls on RBR850
Hi, I have just received the following reply from NG via Twitter Hi , thank you for reaching out. The reason why Parental Control is not available yet in Orbi 6 is because we will be releasing o...
Bschoenbaum
May 18, 2021Initiate
Seems ridiculous it’s taking Netgear this long to get foundational parental controls on its best high speed mesh system. Frankly it’s like giving the keys to the a Ferrari to your 12 year old kid. I’m love the connectivity but I’m so disappointed in a year of the pandemic to not have had strong parental controls. Based on the packaging when I purchased the RBR it certainly appeared they had parental control options, I’m now considering abandoning the router for an alternative as Netgear can’t get it together.
ESciullo
Jun 10, 2021Initiate
I am very disappointed with how Netgear is handling there product support. In Canada I paid approx $900 for the router and the 1 satellite.. The performance is good, but there is NO parental controlls. When I called support they told me to return it if I didnt like it.. I would if I could but it is past the 30days and Amazon will no longer support the return of the product and there is no way I am going to buy another router one.
- FURRYe38Jun 10, 2021Guru - Experienced User
Which Orbi model do you have? 7 or 8 series.
NG said PC is forth coming to Orbi AX.
ESciullo wrote:I am very disappointed with how Netgear is handling there product support. In Canada I paid approx $900 for the router and the 1 satellite.. The performance is good, but there is NO parental controlls. When I called support they told me to return it if I didnt like it.. I would if I could but it is past the 30days and Amazon will no longer support the return of the product and there is no way I am going to buy another router one.
