rr20552
Feb 05, 2021Apprentice
Parental controls on RBR850
Hi, I have just received the following reply from NG via Twitter Hi , thank you for reaching out. The reason why Parental Control is not available yet in Orbi 6 is because we will be releasing o...
ESciullo
Jun 10, 2021Initiate
I am very disappointed with how Netgear is handling there product support. In Canada I paid approx $900 for the router and the 1 satellite.. The performance is good, but there is NO parental controlls. When I called support they told me to return it if I didnt like it.. I would if I could but it is past the 30days and Amazon will no longer support the return of the product and there is no way I am going to buy another router one.
Jun 10, 2021Guru - Experienced User
Which Orbi model do you have? 7 or 8 series.
NG said PC is forth coming to Orbi AX.
ESciullo wrote:I am very disappointed with how Netgear is handling there product support. In Canada I paid approx $900 for the router and the 1 satellite.. The performance is good, but there is NO parental controlls. When I called support they told me to return it if I didnt like it.. I would if I could but it is past the 30days and Amazon will no longer support the return of the product and there is no way I am going to buy another router one.
