JerrySR
Apr 17, 2021Follower
Parental Controls with AX-4200? (RBK 752)
Hi. I purchases the RBK752 system for my house and it's working fine. A good system with Wifi 6 compatibility which will gradually become more useful. However I wonder when or if Netgear will add ...
Apr 17, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Circle product. Most of the people who watch that forum are more likely to have experience with Circle and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
https://www.netgear.com/home/services/smart-parental-controls/
https://community.netgear.com/t5/NETGEAR-Smart-Home-Parental/bd-p/en-home-smart-parental-controls
Good Luck
tak1313
Apr 20, 2021Luminary
Switch to Asus, or put an Asus router between and use Orbi as an AP.
You not only get parental controls, but protection is free as well (AiProtection vs. Armor).
