arees0921
Mar 19, 2021Tutor
Parental Controls
I have a RBS852 AX6000 Orbi Router and 3 satellites. The model number does not appear in this community support... which is very odd. Does anyone know where to setup parental controls per device...
arees0921
Mar 19, 2021Tutor
Thanks, but why is that okay? Short of that, we are forced to deal with it on the physical device and every device is different, What is Netgear's reaction to this? Do we need separate network software? Given the proliferation of devices, including IoT, our lives are made much easier if we can manage access at the router.
Mar 19, 2021Guru - Experienced User
That link is netgears reaction and why. You're welcome to comment on the moderators post where they might actually respond.
the rest of us aren't netgear. We're members of the public trying to help out for free.
And I never said it was ok. I'm just trying to point to an answer to your questions.
- arees0921Mar 19, 2021Tutor
Sorry - didn't mean to suggest otherwise. Thanks for your response
